6 members (Hotrod Lincoln, Peggy M, klhansen, IHPWR, DadsFirstPickup, 49choptop), 87 guests, and 1 robot.
Topics128,043
Posts1,055,605
#139321 09/17/2007 3:23 AM
Apprentice
Apprentice
I am tring to decide what is the best way to go with the rear end on my 51 chevy. I like the coil spring bolt in kits, but I would like to hear from people who have both stock rear leafs, and coil overs. Also what is the best bolt in kit for it? thanks Tony
Tony Jacques
#139322 09/17/2007 8:35 AM
I have the stock rear leaf setup with a DANA 44 rear and 8" wide rims on my 1950. This arrangement has worked fine for me with an early 350 small block up front.
Personally, I wouldn't rush to radically change the stock rear suspension on my own truck, but you don't say in your post what your plans are for the front suspension of your 51, or whether you want to lower the ride height a lot. Then you might be better off with a coil spring setup to get suspension movement at the rear and keep good rear wheel control too.
#139323 09/18/2007 4:02 AM
Stuart:
That steering wheel is on the wrong side mate. grin
~Jim
#139324 09/18/2007 4:08 AM
Tony:
I have installed a chevy 10 bolt rear with a TCI leaf spring kit. It lowers the rear equal with the Heidt's IFS. I haven't finished the project so can't brag yet. My engine is a Chevy 350 crate with 330 horse and not too strong for the rear suspension.
~Jim
