0 members (), 144 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
Is it possible to connect a 4L60E transmission to the original speedometer on a '50 3100? If so, what provisions are required?
A very possible way is Abbott Tachograph here. Never used them but they're a small company that's been around for 50 years. The owner started out designing/building/supplying data loggers/tachographs for the trucking industry.
Good Luck,
RonR
RonR
1970 340 Duster
1964 CJ5
Jegs sell their version of the “cable X” too. Its just a VSS electronic input (from trans) then it has a board that does the calculation and drives a electric motor that drives a stock GM speedo cable. I have seen them previously used in older swap muscle cars and I will be installing one in a turbo LS 50 chevy pickup very soon.
We don't use cable or electronic speedometers anymore but rather GPS units that are not affected by gearing or tire size. Only around $60 but no one has come out with a 5" face one for a direct fit into an AD truck. Someone has dropped the ball on this since there would surely be a market for such. The <> 3.5" face ones with a custom made bezel are okay but not right.
Evan
You can swap the tailshaft housing for one from an older TH700R4, with a mechanical speedo drive. Then you may need a custom-made cable with the correct ends, I do not remember what kind of cable I had used on mine. Changing the tailshaft housing also makes it easy to change the driven/drive gear, so that the speedo is correct.
No electronics, OEM simplicity and reliability.
'57 Chevy Suburban; '70 Chevy Impala.
If your tailshaft is the later 8 bolt version, you're out of luck. The cable x style system is it.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
