| | | Forums66 Topics128,191 Posts1,057,362 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | I am tring to decide what is the best way to go with the rear end on my 51 chevy. I like the coil spring bolt in kits, but I would like to hear from people who have both stock rear leafs, and coil overs. Also what is the best bolt in kit for it? thanks Tony
Tony Jacques
| | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | I have the stock rear leaf setup with a DANA 44 rear and 8" wide rims on my 1950. This arrangement has worked fine for me with an early 350 small block up front.
Personally, I wouldn't rush to radically change the stock rear suspension on my own truck, but you don't say in your post what your plans are for the front suspension of your 51, or whether you want to lower the ride height a lot. Then you might be better off with a coil spring setup to get suspension movement at the rear and keep good rear wheel control too. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Stuart: That steering wheel is on the wrong side mate.
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Tony: I have installed a chevy 10 bolt rear with a TCI leaf spring kit. It lowers the rear equal with the Heidt's IFS. I haven't finished the project so can't brag yet. My engine is a Chevy 350 crate with 330 horse and not too strong for the rear suspension.
~Jim
