| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I thought my powerglide was going out it was making nose found out it is the rear axle. It will cost around a $1000 to rebuild but the mechanic told me to get a new one that has disc brakes and then buy a kit to change the front to a disc brake. I like the idea but not sure which rear axle to look for. Thanks for the help I have a 1966 Chevy truck step side short bed
Rocky
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You would likely have to find a much later rear end to get disc brakes. In addition, many newer rear end assemblies have leaf springs so it would have to be modified. This would include welding, changing brake lines, and brake cables to adapt to your coil spring rear suspension components. Front disc brake conversions are available from a variety of aftermarket suppliers and would include an upgraded booster/master cylinder. All of this would cost way more than $1000. While I believe the front disc brake conversion is the way to go, I would seek a second opinion from someone that specializes in rebuilding rear ends. Fred
| | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I was told it could cost up to $1000 dollars but it depends on what is wrong the labor will be $500. I am still going to try and find a rear axle from an unused truck and install it, if I can't find one I'm not in a big hurry | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | I am still going to try and find a rear axle from an unused truck and install it, if I can't find one I'm not in a big hurry Good luck finding an axle from a UNUSED truck.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I meant one that's not being used like wrecking yard | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | I meant one that's not being used like wrecking yard I knew that's what you meant, but just couldn't help my self at issuing a dig for your wording.  I hope you find what you need.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | Thanks, I hope so too I'll save a little money | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | i would think you could find your axle in a junk yard out there for not much money. Curious to know what is specifically wrong with your current axle. | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | there is all kinds of metal in the oil so I'm guessing ring and pinion | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I've been telling guys to look into the 04-12 Chevy Colorado/Gmc Canyon rearends. They have the 6x5.5 bolt pattern and gearing options from 3.27 to 4.11. They come in 60" to 63" wms. Now, they are drum brake equipped and the center hub is larger than the earlier axles. So, you'll prabably need some aftermarket wheels. You can upgrade to discs using parts out of the GM parts bin. I know around here, I can get one out of the salvage yard for less than $200.
| | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | That sounds very interesting and something I can find in a wrecking yard. I don't completely understand everything like what is wms. I have given up on disc brakes so drum is fine. Just need to know which truck to get it from and I don't have stock wheels. I have 6 lug 5.5 I would need more information not that mechanical. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | WMS..... wheel mounting surface.
| | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I have 350 so what gears would I want | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I'm not familiar with Powerglides, but 3.42 and 3.73 seem to be the most common in these rearends. I'm going to say 3.42 for cruising, but 3.73 for a little more get up and go. | | |
