4 members (Gdads51, Gib70, tclederman, Gray_Ghost), 158 guests, and 3 robots.
Topics128,078
Posts1,056,021
Members48,433
#1392523 01/13/2021 6:40 PM
Tried my hand at soldering a small leaK in the heater core. It's not pretty but after applying about 2psi of pressure to it no visible sign of leaking and maintained pressure overnight!
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
That's pretty good for using a torch for soldering. Better results (and less chance of damage) are obtained with an old school soldering iron (A big chunk of copper with a handle that gets heated up with the torch).
In hunting for a picture to show you, I saw a bunch on eBay - People are asking crazy prices. There are 4 or 5 of them in my Dad's tool shed. Maybe I should cash in. wink
Like This:
An entrepreneur with a hacksaw, a file, and a chunk of copper could fabricate one and "antique" it - - - - -and still cash in on some people's gullibility!
I would put more than 2psi to test it for leaks
When setting goals in life. Always aim low to avoid disappointment
2 Offline
I thought that these old trucks usually had a about a 4psi radiator cap, maybe 2-6psi depending what you were doing, my radiator shop rebuilt my radiator and checked this round heater core for leaks after flushing it. They provided me with a new 4psi cap and thanked me for not doing my own pressure test to modern levels.
-s
3 1/2 to 4 1/2 PSI cooling system
140-147 or 148-156 thermostat, fulling open at 170 or 176 degrees
Thanks for the replies.
I mentioned I applied "about 2 psi" using a old bike tube with valve sealed on the inlet and outlet. I used a hand bike pump with integrated gauge to ensure that I didn't put to much pressure on the core.
I'll try to get a picture of the setup and post it.
Try 4 psi ?
