Brrrr
place holder
1 members (Peggy M), 134 guests, and 3 robots.
Topics128,271
Posts1,058,414
Members48,485
I have a '81 Camaro rear end under my '50 3100. It's within a half inch + or - on each side of what the original torque tube rear measured. What is the widest wheel that I could conceivably fit inside the fenders without tubbing the box? I realize offset plays a part. What have you other bolters been able to squeeze in?
I'm going to be running 11.5". I have to run under 12" for the class I want to run in. I don't like the tub look so I will be widening my rear fenders 2". It's a relatively easy process. Just from measuring you might be able to fit a 10" but I have never tried it. 53/3100.
Insomniac
Insomniac
I have a 78 Camaro rear end. Wheels are 15" x 7" wide with a 4" backset. Tires are 205 75 R 15. Wheels just touch the box on hard cornering.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I plan on using a 20" wheel. I've installed 3" lowering blocks...hoping they will fit diameter wise. In regards to wheel width, I hope I can at least get 8 inches. I'm not going to purchase any tire/wheel combination until the fenders are mounted.
Gord&Fran...I assume you meant the TIRES touch the box on hard cornering?
I have a BIG 10 rear end under my 49 running Ridler 18X8 wheels with 4 1/2" backspace with Fuzion 235/45R18 Tires.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Zippi, those shock towers look so much nicer then the bar between the frame rails I have (76 trans am rear). Are they available online? or did you custom fab them? thx
PS, I have a bunch of fixing required here to fix poor welds/fabs made by PO frown
1951 Chevy 3100
"Project for my Wife" - Jigsaw Puzzle
1969 Camaro SS350 convertible
1969 Camaro 327 convertible
The PO fab the shock towers.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Crusty Old Sarge
Crusty Old Sarge
Zippi, are your rear springs moved under the frame rails? I did that on a 56' 210 I had, I was able to run a 12" tire by doing that.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Insomniac
Insomniac
Yes, the tires just touch. That means wheels with less than 4" backspace would be a problem for me. Using Camaro stock drum brakes.
Gord 🇨🇦
Yup. Mounted to the frame rails.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
