| | | Forums66 Topics128,131 Posts1,056,722 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | I am restoring a hood emblem for my '50, and does anyone know of the thread size for the screws that attach it to the back side ? I'll have to re-tap the threads, Many thanks, Mike | | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | About 8 months late, but the four on mine are 1" 10-24 bolts/screws. Just busted one of mine taking it off to change the rubber base and put new decals on it. For some reason, my local hardware store doesn't carry them. Also, even though classic parts and lmc carry new emblems 'with all hardware', they don't carry replacement screws for old ones. Now I'm finding that if I order any from McMaster Carr or amazon, i'll have to get at least 25 of them to get one. Surely somebody carries this size bolt in hex head!
"When I rest, I rust" 1951 3100 5 window w/ '56 235
| | | | | Joined: Nov 2020 Posts: 788 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 788 | Got mine at the local "True Value" hardware store.
Regarding McMaster-Carr , 25 is a lot , but I bet the dollar amount is still small. | | | | | Joined: May 2015 Posts: 11,117 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,117 | If you look hard enough, you could find hex head 10-24 screws, but the ones on my '51 hood emblem were not hex head. I don't recall for sure, but they may have been pan head clutch drive screws. Full disclosure though, I found that someone had replaced half the hood way back when. Could be they didn't reuse the factory screws.  No one is going to see them on your completed truck anyway, so just get what's readily available.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
