| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Has anyone used these?Please do not post your opinions, if you have not used them. The reviews that they show might be bogus Thanks | | | | | Joined: Aug 2001 Posts: 3,588 Moderator | | Moderator Joined: Aug 2001 Posts: 3,588 | Never used them so I guess I can't post. But I will say, being a retired machinist. I would not buy them. Self drilling/tapping screws do work well on mild steel.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: May 2015 Posts: 11,002 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,002 | Since Don has already broken the rules, I’ll jump in.  They will only work on thin material. If the drill tip hasn’t broken through the tap portion won’t start.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,748 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,748 | I have used more professional-looking drill/tap combinations than those Mickey Mouse things. If a regular combination drill and tap device is used with a radial drill press or a Bridgeport mill with the power feed set to advance the tap at the pitch of the thread, through thin material in a production situation where dozens of holes need to be drilled and tapped, they work. I don't think I'd use the ones pictured if someone gave them to me, let alone buy them. Jerry
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | I use a version sold to me by Kimball Midwest. Easy to break if you're not careful. As usual, lots of oil, advance slowly. Don't drill sideways. | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | I have used them, in my opinion they are good for the homeowner and occasional metal work. My opinion is that a high quality drill set and very high quality taps cannot be beat. Gimmicks come and go but high quality bits, taps and dies will stay with you for your life. Lubricate and go slow is my method and 90 degree set angle will be assured. Doc.
