2 members (FAST55, Rusty Rod), 96 guests, and 2 robots.
Topics128,026
Posts1,055,404
Members48,422
#1391698 01/08/2021 1:35 AM
Has anyone used these?Please do not post your opinions, if you have not used them.
The reviews that they show might be bogus
Moderator
Moderator
2 Offline
Never used them so I guess I can't post.
But I will say, being a retired machinist. I would not buy them.
Self drilling/tapping screws do work well on mild steel.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Since Don has already broken the rules, I’ll jump in. wink
They will only work on thin material. If the drill tip hasn’t broken through the tap portion won’t start.
I have used more professional-looking drill/tap combinations than those Mickey Mouse things. If a regular combination drill and tap device is used with a radial drill press or a Bridgeport mill with the power feed set to advance the tap at the pitch of the thread, through thin material in a production situation where dozens of holes need to be drilled and tapped, they work. I don't think I'd use the ones pictured if someone gave them to me, let alone buy them.
I use a version sold to me by Kimball Midwest. Easy to break if you're not careful. As usual, lots of oil, advance slowly. Don't drill sideways.
I have used them, in my opinion they are good for the homeowner and occasional metal work. My opinion is that a high quality drill set and very high quality taps cannot be beat. Gimmicks come and go but high quality bits, taps and dies will stay with you for your life. Lubricate and go slow is my method and 90 degree set angle will be assured. Doc.
Moderated by  MNSmith
