2 members (Ole49GMC, Hush),
74
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2021 Posts: 9 New Guy | | New Guy Joined: Jan 2021 Posts: 9 | Hi, I have a new 1952 Chevy 3100 with standard 3 speed transmission. My speedometer is not working. Have new speedometer, cable and I have eliminated those and the driven gear. I found that the drive gear in the trans is spinning on the shaft. Can anybody tell me what holds this in place and how to get it out? Also can it be done with the transmission in place? I know the torque tube has to be dropped out of the way. Any help or pictures would be helpful.
thanks, Gary | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I had trouble with mine too, on a 4 speed. I tapped mine back and off the shaft if I recall correctly. I think it is a press fit. I did not need to take out my transmission. | | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | The gear is held on the shaft by the u-joint. You will need to lower the torque tube and the u-joint to gain access.The tranny side of the u-joint is held in place by a bolt going onto the shaft. Maybe you’ll get lucky and just have to tighten the bolt. There is an excellent video on YouTube by Jayhawker on the SM318 rebuild. Its in two parts. Look up “Part 2: 1937-1954 Chevrolet 3 Speed Transmission Rebuild - Reassembly” and between 30:33 and 32:15 shows the gears being installed.
Hope this helps!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2021 Posts: 9 New Guy | | New Guy Joined: Jan 2021 Posts: 9 | I saw that video but he never explained the press fit. Is the drive gear made on the tube he slides over the shaft? Is there a washer that goes on before the u-joint? I am willing to tear into this if it is not too hard or expensive.
thanks, Gary | | | | | Joined: Jan 2021 Posts: 9 New Guy | | New Guy Joined: Jan 2021 Posts: 9 | Also he has the trans out and says he shifts into two gears at once. With the trans in the truck I can only shift into one gear. will this work to tight the yoke? | | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | As long as the the clutch is released and the transmission is in gear, you can loosen/tighten the bolt holding on the u-joint. In the video he didn’t have the engine to keep the tranny from turning. The speedo gear on the tranny tail shaft is a slip fit. It is held in place by the u-joint when its tightened to the tail shaft. There is a spacer that goes on before the speedo gear. The hardest part is getting the torque tube dropped enough to get the u-joint removed. Changing the gear if required is easy. Here is the tranny breakdown from the Chevrolet Truck Shop Manual.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2021 Posts: 9 New Guy | | New Guy Joined: Jan 2021 Posts: 9 | Okay, thanks for the info. I will be getting to it soon. | | | | | Joined: Jan 2021 Posts: 9 New Guy | | New Guy Joined: Jan 2021 Posts: 9 | Do you know how much torque is on the bolt that holds the yoke in place? I tightened pretty good but the speedo gear was still slipping. I didn't want to break the bolt. | | | | | Joined: May 2015 Posts: 11,156 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,156 | 15-20 ft-lb per the shop manual. Sounds like you need a slightly thicker spacer or shim so the speedo gear will tighten up.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the spacer tube is worn on then ends from not being pinched tight between the yoke, and the speedo gear, it may not be able to pinch tight now without a shim. Sometimes flipping over the washer on the yoke helps, if it has become concave.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2021 Posts: 9 New Guy | | New Guy Joined: Jan 2021 Posts: 9 | Got the drive shaft all back together and speedometer drive gear is working but speedometer still has issues. When I took it for a test drive using my gps speedometer to gauge my progress at 30 speedo showed 10 at around 45 it jumped quickly to 70 and would not come down till I was back around 30. I think the speedometer head is now the problem. Someone replace it with a new one but I think it is defective. Going to pull it out of the dash and inspect. Any suggestions or have you seen this before. I check the cable and it is new and the speedometer is not bouncing, just not registering. Thank you all for the help. | | | | | Joined: Jun 2005 Posts: 16 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 16 | Hi. When you say it is a slip fit, do you mean that it should spin freely on the main shaft? It doesn't seem right that mine spins freely. Wouldn't that make it really inaccurate? I've been considering peening in some divots to make it "catch" onto the main shaft. Stop me before I damage a possibly irreplaceable part! | | | | | Joined: May 2015 Posts: 11,156 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,156 | Hi. When you say it is a slip fit, do you mean that it should spin freely on the main shaft? It doesn't seem right that mine spins freely. Wouldn't that make it really inaccurate? I've been considering peening in some divots to make it "catch" onto the main shaft. Stop me before I damage a possibly irreplaceable part! It's a slip fit in order that it can be assembled easily, along with the spacer. There should be no need to peen anything. The above posts should give you all the info you need to make it work. Most likely possibility is the washer getting dished - just flip it over. If the speedo gear still spins with the u-joint bolt torqued properly, then you may have a spacer that's too short (having worn down from the speedo gear spinning). You could put a few center punch marks around the face of the u-joint yoke to upset some metal and make it effectively longer.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | Hi. When you say it is a slip fit, do you mean that it should spin freely on the main shaft? It doesn't seem right that mine spins freely. Wouldn't that make it really inaccurate? I've been considering peening in some divots to make it "catch" onto the main shaft. Stop me before I damage a possibly irreplaceable part! Were still talking about the transmission where the speedometer gear slips on the tail-shaft, correct? If so, as Kevin has already said, the gear is a slip fit on the tail shaft until the yoke is installed and torqued. This should tighten the gear so it won’t slip. If it does, as”Pre ‘68 Dave” has said, either flip the washer or install a shim to tighten the gear.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jun 2005 Posts: 16 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 16 | I think I get it now...
When I torque the U-joint it will put pressure on the u-joint spacer(#17) which is in contact with the speedo gear (#16) which is in contact with the speedo gear spacer (#15) which is in contact with the inner race of the main shaft rear bearing (#13). The speedo gear becomes "sandwiched" and therefor remains locked to the main shaft.
Do I have that right? | | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 |
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jun 2005 Posts: 16 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 16 | Thanks to klhansen and Phak1! | | |
