3 members (Gib70, Woodcmiami, Danielbolt), 318 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
Ok what is the best thing to do? I have already bought the brake booster and kit, only to once I recieved the truck to find out that it has a hyd clutch. I don't want to remove the Hyd Clutch if I don't have to. I know that CPP has a booster that has a reservoir for the clutch with it. Has anyone every done this with out using kited parts. If so what did you use for the clutch master cylinder?
Mark
you could try a single clutch master from an 88-92 C1500 w/manual trans or maybe an aftermarket racing unit, otherwise it is switch to linkage.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I would do away with the hydraulic clutch if at all possible.
I have nothing good to say about the idea of a hydraulic clutch linkage.
Manual linkage gives no problems.....
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Quote
Grigg
Sometimes it does get worn after 50-60 yrs, but that's about it
