1 members (3800rao),
102
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 36 | Ok what is the best thing to do? I have already bought the brake booster and kit, only to once I recieved the truck to find out that it has a hyd clutch. I don't want to remove the Hyd Clutch if I don't have to. I know that CPP has a booster that has a reservoir for the clutch with it. Has anyone every done this with out using kited parts. If so what did you use for the clutch master cylinder?
Thanks, Mark | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | you could try a single clutch master from an 88-92 C1500 w/manual trans or maybe an aftermarket racing unit, otherwise it is switch to linkage. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I would do away with the hydraulic clutch if at all possible. I have nothing good to say about the idea of a hydraulic clutch linkage.
Manual linkage gives no problems.....
Grigg | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by Grigg: I would do away with the hydraulic clutch if at all possible. I have nothing good to say about the idea of a hydraulic clutch linkage.
Grigg Sometimes it does get worn after 50-60 yrs, but that's about it | | |
