| | | Forums66 Topics128,140 Posts1,056,774 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 281 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 281 | I had the tire off the back end and I thought "if I turn the brake drum one full revolution and count how many time the drive shaft turns I could verify my gear ratio". Am I thinking correct or am I mistaken?
1947 3600 Chevy
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | That is correct Block the other side Chalk mark both axle and wheel And you will get 2x the normal turns on one wheel with the other blocked
Example I block one wheel on my truck Make 10 turns on the wheel and see about 25.5 turns of the input shaft 10/2 = 5 turns of both wheel if I was on the road 25.5/5 = 5.1 so that’s a 5.13 according to the books -s | | |
