4 members (Donf, FAST55, Shaffer's1950, greenie-reddy), 34 guests, and 3 robots.
Topics128,154
Posts1,056,838
Members48,456
#1391537 01/06/2021 6:59 PM
I had the tire off the back end and I thought "if I turn the brake drum one full revolution and count how many time the drive shaft turns I could verify my gear ratio". Am I thinking correct or am I mistaken?
1947 3600 Chevy
2 Offline
That is correct
Block the other side
Chalk mark both axle and wheel
And you will get 2x the normal turns on one wheel with the other blocked
Example
I block one wheel on my truck
Make 10 turns on the wheel and see about 25.5 turns of the input shaft
10/2 = 5 turns of both wheel if I was on the road
25.5/5 = 5.1 so that’s a 5.13 according to the books
-s
