3 members (Rexville48, 59 fleet, Otto Skorzeny), 121 guests, and 2 robots.
Topics128,070
Posts1,055,896
Members48,428
#1389690 12/24/2020 6:50 PM
I’m getting close to the time when I can start my ‘51 streetrod project and I am collecting parts. Was wondering if you guys could tell me which vehicle from the junkyard provides the nicest bench seat in terms of fit and comfort? I talked to a fellow one time who had put a bench seat from an Isuzu truck in his Chevy. It looked pretty nice.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
I have seen threads that an Astro van or Yukon 90's ish second row seat works well and has integrated seat belts and shoulder harnesses. Just what I have read.
A lot of the S10 conversion guys use mid-90s Chevy pickup bench seats. Nothing fancy, but they fit pretty well.
1951 Chevy Panel Truck
Crusing in the Passing Lane
S-10 bench seat works well for me.
Ed
It makes sense that the S-10 seat would fit. Thanks for that suggestion. I’ll start looking around for one to test fit.
Anybody else have luck using another model seat??
Chuck
1941 Chevy coupe
I'm using a mid-90s Silverado seat, 60-40 type, the center seat folds down to a nice console/armrest.
Just a question, what's wrong with the factory bench seat? Why not recover the original? If you're springs are in bad shape, I've seen on other forums where guys have instilled plywood and cut out a thick piece of foam and covered it.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I have a set of bucket seats out of a 2000 suburban with integrated seatbelts. You need to measure your cab and see if a bench from a newer full size pickup will fit. Or find the S10 or Colorado seats.
Another quality post.
Real Trucks Rattle
silverado probably too wide for early truck. my '37 can only handle around 46". '40-early '47 grew a bit but not much before the AD's
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Whitedog, I’m not a bucket seat kind of guy, so I’ll stay with a bench, but I thought that I’d put in a more modern looking seat instead of staying with the old original. Maybe leather?
Thanks Rusty and 37 GC. I’ll measure mine and take the tape measure with me to the salvage yard and see what possibilities there are.
Chuck
1941 Chevy coupe
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
I have seen a 47' with a 60/40 split seat from a mid 90's (insert "F" word here) Ranger. It had a fold down arm rest in the center and tilted forward, the width was spot on for the cab.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
TUTS59..... putting a F*** seat in my Chevy??? Blasphemy!!!
Chuck
1941 Chevy coupe
I'm using a simple bench seat out of a mid 90s full size Chevy pickup. It fits perfect running almost from door-to-door. I'm using the stock 90s seat riser. It is extremely comfortable and moved me back about 4" even with the gas tank in its stock location.
Fox Offline
I second TwoTone. I removed my original riser, welded in a 1” riser on the floor and bolted down a 1990 GMC Sierra bench seat using its pedestal. As mentioned, it sits just below the rear window, moves you back and down a lot, gives ample head room, and you can use the stock tank. I have had my bro in law and a buddy (both 6’3”) get in and they can’t believe that it has as much room as it does. I’m 6’ and it is the perfect “hang my elbow out the window and cruise height”. It does fill the cab from door to door with about 3/8” between the door and bench seat side, but I can overlook that. It’s not modern comfortable but the steering wheel isn’t in your stomach, you’re not pushed forward, and you can lean back and relax. Plus, the seat folds forward for access behind the seat. It’s been a great choice in my mind. I’m doing it again on the 1/2 ton project.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox, I love the seat you used. Looks like it belongs in an old truck. The slanted back must really improve the feel while driving. I always feel like my original bench seat back is pushing me forward and I can’t ever relax. I’ll keep my eyes peeled for one like yours. I appreciate your comments too Twotone! Thanks gents!!
Chuck
1941 Chevy coupe
I’m using the rear seat from an Avalanche.
Robert C.
I'm a Genius in the making.
1950 3600
It has been hard around here, to get a seat with driver’s position in good shape.
Ed
That might be an ingenious idea. The rear seats are in better shape than da front. thumbs_up
What I also like about them is this the easy access to the storage behind and underneath them. The bottom lifts up and the back folds completely forward. I have the TPI ecu and powered sub underneath. I have a new wiring harness that I plan on mounting the fuse panel there as well. I’m getting too old to contort my body to get under the dash!
Robert C.
1950 3600
Liking it more and more. Good job.
Dodge Dakota bench seat ($75 from the scrap yard) worked great for me after it was re-covered and some new foam was added. Raised it on an upholstered platform about 5 inches, with room beneath for subwoofer speakers and a hiding spot for my wallet. The seat back folded forward and was a good spot for the fire extinguisher. The rear back height was level with the rear window.
Cheers, John
