3 members (Ponchogl, 68ironhead, 3B), 45 guests, and 3 robots.
Topics128,026
Posts1,055,403
Members48,422
#139115 08/20/2007 5:43 AM
I know alot of you run the Howard M4F Cam, so I hope this is not a dumb question.....But, the card reads .014 for intake & .016 for exhaust, fine, then it says to set the valves .005 tighter than recommended for running, to compensate for loosening during break in. I'm sure this is tried & true, but in my head it seems tight, has everyone set their valves with this cam to the letter as stated in the directions? And not had any problems? O.K really dumb question #2, if I set the valves .005 tighter, I will have the intake at .009 & the exhaust at .011 correct? Thanks in advance.
#139116 08/20/2007 6:44 PM
Yes, that is correct. The cam will wear some during the initial break in, faster then than at any other time, thats the reason for less lash to start with. After you go through the break in period go back and check the lash again. I'd check the lash a couple more times after you run it the first couple times.
#139117 08/20/2007 7:18 PM
After break in, always check the lash hot.
Bill Burmeister
#139118 08/21/2007 5:21 AM
Kevin S - Bill, Thank You!
