| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | I have removed the bed wood and am in the process of removing the bed. But I don't know how to handle the somewhat flimsy sheet metal on the bottom when I store it. How is this done? Do I need to store upside down?
Thanks for any advice.
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | What you're working on would help people answer your question.
You can put that info (Year and model for instance) in a signature that appears in all your posts, so you don't have to tell everyone each post. Click on your username on the upper right of the page and on "Edit Profile" on the pulldown.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | Sorry I forget that sometimes. I put it in my signature.
| | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | Would there be any problem with disassembling the bed panels? Since I cannot figure out how to store it off the truck, without turning it upside down, I'm thinking this may be the best way to ensure that the lower portions of the fleetsides do not get damaged.
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | I don't know about a '65 bed, but the AD series bed sides were welded at the rear to the cross sill. If yours isn't welded, I don't see any issues with disassembling the bed for storage. If you have the room, storing it upside down on the flat tops of the bed with some dunnage underneath to keep it off the ground/floor seems like a reasonable approach.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | There is a weld or 2 and then a number of bolts. If you dont need to for sheetmetal repairs, I recommend you keep it assembled. It likely is as square as it is going to be. You can block it up on the cross members. I would not be comfortable for it to rest on the lower edge of bed side as you have already concluded. In my case I built a crib on casters. 4x4 posts housed the casters and then I ran 1x6 skirt and braced. I built it at a ht I could get under the side and low enough I could climb over the side. Rolled around my garage and drivewaay for a year or more like that. I would do it that way again. | | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | Looks like constructing a crib is going to be necessary. The added complication is transporting bed to the paint/body shop. My crib will just have to be sufficient enough for that.
Thanks for the help. I would not attempt this project without you guys and these forums.
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Stand it up on the front (cab end) on a couple of blocks of 2x4's to keep it off the ground.
Tommy 59 apache 1/2t 261 short stepside | | |
