0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 7 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 7 | I want to purchase a rear end for this truck. It is currently on a caprice frame. I found a stock frame but it does not have a rear end. I have received quotes for complete rear ends from two companies. One says the stock rear end width is 56 inches and the other says 62 inches. Does anyone know the correct stock rear end width (axle flange to axle flange). Thanks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2020 Posts: 7 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 7 | Thanks. I saw that diagram. Is there a way to determine the axle flange to axle flange from the diagram? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Lsuman99 I am 65 miles down the road in Metairie, la., have one from a 57 will measure in a little bit when the sun gets higher in the sky. I have a 59 shortbed stepside also. Check your mail I can't send you a private message about the rear end.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Looks like 62-62 1/2, the axles are not in mine right now, as I have it taken apart.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I don't know how original you're wanting to stay, but.... Have you thought about a modern rearend? The 04-12 Chevy Colorado Z85 and Z71 trucks had a rear that was 60-62" wms. They have a 6x5.5 bolt pattern, but metric lugs. The rim centers are larger, so aftermarket wheels would be required. You can get ratios from 4.10, 3.73, and 3.42. A quick search on car-part.com show they can be had for cheap all over the country. | | | | | Joined: Dec 2020 Posts: 7 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 7 | Thanks guys. 62" is it. I ordered a new Currie rear end with a 3.70 gear ratio. | | |
