10 members (Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 1 invisible),
58
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Is it possible to burn valves and doing engine damage driving about 3-5 miles with open headers to a muffler shop to get exhaust connected to headers? Recently read an article someone thinking they damaged there engine doing just that driving to muffler shop Engine in question is a 235 Chevy.
This is no longer fun
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | That's a myth. I've run racing engines with open headers for hundreds of laps with no valve damage whatsoever. Maybe if there was no exhaust manifold at all, there might be a little bit of exhaust valve damage, but even then, the engine would have to be run at wide open throttle uphill for miles. Jerry
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | That's a myth. I've run racing engines with open headers for hundreds of laps with no valve damage whatsoever. Maybe if there was no exhaust manifold at all, there might be a little bit of exhaust valve damage, but even then, the engine would have to be run at wide open throttle uphill for miles. Jerry thanks I’m weighing my options to get my truck to a muffler shop
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Latroca 52 At the dirt track you see the rough guys race without the manifolds even on there. At night you could see all the valves were red hot they ran all evening ! | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | WW2: 100,000 war planes and not one muffler | | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Thanks for reply’s just trying to figure out drive the truck to the muffler shop or have it towed to the muffler shop it’s probably 10 miles away or less. Duel exhaust need be redone after installing Fenton headers and removing split manifold
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Sounds like a giant leap backwards- - - - -what are you doing for intake manifold heat? Jerry
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Sounds like a giant leap backwards- - - - -what are you doing for intake manifold heat? Jerry I installed a Fenton duel carb intake manifold with the heat plate and copper tube connected to the exhaust manifold.
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Be nice Jerry ... 😉
Lots of guys love the looks and sound of a dual/dual setup on a straight 6 – else they wouldn’t have been selling them for 70 years.
I agree, modest gains in power will be achieved...
Professional Novice
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | It takes a very creative approach to plumbing in order get any heat to the intake with that heat plate- - - -it's mostly there for looks, and it doesn't supply anywhere near the same amount of fuel atomization from heat transfer that a stock exhaust manifold provides. Plus, a 2-carb setup needs a lot more, not less heat to work efficiently. Splitting a stock manifold, or finding one of the "scarce as hens' teeth" Corvette dual exhaust manifolds is a much better approach. Like somebody said a while back, fancy intake and exhaust systems components are not "fashion accessories". Jerry
