7 members (Gdads51, Lightholder's Dad, ShopRag, Hotrod Lincoln, sudsyz, Chip O, 1 invisible), 77 guests, and 0 robots.
Topics128,210
Posts1,057,456
Members48,471
Looking for the toque specs of the cylinder head bolts on the 216 engine as well as the rocker arm supports. Thank you.
Philippe Jeanneau
H Online: Content
If the head bolts are 1/2-13, torque them to 90-100 ft/lbs in 3 steps- - - -50, 65, 100, lubed with motor oil. Start in the middle of the head and work toward both ends. Rocker arm stands are 3/8"- - - -30-35 ft/lbs.
The 1948 to 51 shop manual specifies the head bolt torque as 70 to 80 ft lb.
1951 1 Ton Completed
