| | | Forums66 Topics128,205 Posts1,057,427 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 330 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 330 | Looking for the toque specs of the cylinder head bolts on the 216 engine as well as the rocker arm supports. Thank you.
Philippe Jeanneau
| | | | | Joined: Feb 2004 Posts: 29,887 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,887 | If the head bolts are 1/2-13, torque them to 90-100 ft/lbs in 3 steps- - - -50, 65, 100, lubed with motor oil. Start in the middle of the head and work toward both ends. Rocker arm stands are 3/8"- - - -30-35 ft/lbs. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The 1948 to 51 shop manual specifies the head bolt torque as 70 to 80 ft lb. | | |
