0 members (),
89
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 330 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 330 | Can anyone indicate the torque specs for the flywheel bolts They're 3/8-24 x 7/8. Also looking for the bellhousing to block torque. Thank you.
Philippe Jeanneau
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Bellhousing to block bolts are 7/16- - - -50-55 ft/lbs
Clutch cover to flywheel- - - -30-35 ft/lbs
Flywheel to crankshaft on later model 216 and 235- - - -7/16- - -50-55 Jerry
| | | | | Joined: Jan 2019 Posts: 330 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 330 | Thank you very much Jerry, I might go 40 lbs on the crankshaft bolts since they're 3/8". This is an early engine..
Philippe Jeanneau
