4 members (Gdads51, 60steve, 78buckshot, Alex52), 76 guests, and 1 robot.
Topics128,212
Posts1,057,468
Members48,471
Can anyone indicate the torque specs for the flywheel bolts They're 3/8-24 x 7/8. Also looking for the bellhousing to block torque. Thank you.
Philippe Jeanneau
Bellhousing to block bolts are 7/16- - - -50-55 ft/lbs
Clutch cover to flywheel- - - -30-35 ft/lbs
Flywheel to crankshaft on later model 216 and 235- - - -7/16- - -50-55
Thank you very much Jerry, I might go 40 lbs on the crankshaft bolts since they're 3/8". This is an early engine..
Philippe Jeanneau
