5 members (lc_btv, Leo, FAST55, MickeyP, 1 invisible), 85 guests, and 1 robot.
Topics128,050
Posts1,055,673
#1390348 12/30/2020 1:03 AM
I found a different engine and it is most likely a 216 by looking at it. Can you guys identify the details?
1947 3600 Chevy
2 Offline
from Master Parts Catalog April 1950
that casting number is consistent with a 216 block for all model years 1948-49 that use that engines size
-s
3835253 was used on 1948-1949 216 blocks (car and truck)
1 26 9 block date casting code
January 26 1949
Engine Serial Number (truck)
GBA868672 \
GBA8b8b71 |--> the b and 6 stamp-tools might have been used "interchangeably" on the assembly line
G = 1949
B = 3100
A = regular engine = 216
86872-1000 = 85872 truck off the assembly line at that assembly plant in that model year
January 26 1949
GBA868672 \
G = 1949
Tim,
I'll make a few corrections it you don't mind...
The "B" indicates it's a 3100 truck and that it's the regular 216 engine.
The "A" is the engine plant identifier..."A" = Flint, "M" = Tonawanda.
Also, the unit number on the engine is from the engine plant and each plant started at 1001 regardless of the engine code. So this engine is the 867,672nd engine built at Flint for the 1949 model year, there is only 1 serial number 1001 from each plant.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks for the corrections, Mike
I did the “research” on a notebook computer that does not make for easy reading of details on multiple pages/screens. I should only use this for reading.
dang
