10 members (Tronman, Steelonsteel, Peggy M, Rusty Heaps, J Lucas, Wally / Montana, Scott, klhansen, 2 invisible), 65 guests, and 1 robot.
Topics128,206
Posts1,057,433
Members48,471
Looking for the toque specs of the cylinder head bolts on the 216 engine as well as the rocker arm supports. Thank you.
Philippe Jeanneau
If the head bolts are 1/2-13, torque them to 90-100 ft/lbs in 3 steps- - - -50, 65, 100, lubed with motor oil. Start in the middle of the head and work toward both ends. Rocker arm stands are 3/8"- - - -30-35 ft/lbs.
The 1948 to 51 shop manual specifies the head bolt torque as 70 to 80 ft lb.
1951 1 Ton Completed
