2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#1390037 12/27/2020 6:36 PM
Hey guys Merry Christmas, been a while and I’ve been busy but it’s time to paint the drivetrain and cab undercarriage.
I’m using an Epoxy Primer then top finishing the undercarriage with Raptorliner. My question is, do I need to coat the wooden floor with something prior to the Epoxy Primer to get reliable adhesion?
Thanks!
I contacted a boat builder and they recommended a penetrating epoxy. Runs like water soaks in well. Especially the ends...
Seals the wood fibers and is flexible. Worked out well. It requires a topcoat for UV protection.
Clear Penetrating Epoxy - Epoxy Sealer For Wood - JamestownDistributors.com.
Mike
Last edited by tclederman; 12/29/2020 7:11 PM. Reason: moderator changed "us" to "UV" if this is incorrect PM moderator
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
Thanks Mike, I'll check it out.
If your interested, I use a PPG industrial,enamel called ALK -200. Works great as a paint for the chassis.... I also use it for the body paint because I don’t care for the wet look of the base/clear modern paints. I believe it gives a more authentic look to the car.
PM me if you want to talk about it.
Mike
You're speaking my language, I fully agree on not caring for the base/clear look. I'll be running the existing body color for a year or so with the clear knocked down by scotchbrite until I can decide what color I want it to be.
