5 members (Gdads51, TUTS 59, 55shaker, MikeStone1953, Wally / Montana), 138 guests, and 1 robot.
Topics128,109
Posts1,056,258
Members48,437
Apprentice
Apprentice
I remember a discussion on 8 lug disc brake conversion from drum brakes. Anybody remember what parts were used, or what donor vehicle. It seems to me there was a trick or something you had to watch out for. Thanks for your help,
Ranger
Because of God's Grace,
Ranger Ric
Micah 6:8
Remember if you are driving one of those other things.....stop it!
visit our homepage for pictures of my trucks and our dogs. http://www.rainydaysmastiffs.com
I'm making that change also on my 55 truck however will change to 6 lug first...Lot's of kits available for that.
Keith
Hi Ranger,
If you search the archives for 3/4 ton disc brake conversion you will find a couple of long threads on the subject. The parts used required light machining of the spindle to match the wheel bearings, and a large bracket to mount the caliper. I've taken a different route in adapting discs to my 59 3/4 ton. First I wanted a bolt on application requiring no machine work to the existing truck, second I wanted to use easily available parts (NAPA or equivalent), and third I wanted a caliper assy with it's own bracket which will make adapting to the spindle much easier. The rotor chosen is 72 or 73? (sorry can't remember exact year off the top of my head, I do have the part #'s) Ford F250 3/4 ton used with dual piston calipers. I chose this rotor because it is thinner than most 3/4 ton rotors and opened up my choices for calipers. It also uses bearings with an ID slightly bigger than the spindle. An evening on the lathe and I've made adaptor sleeves and the rotor is mounted on the stock spindle. The caliper used is a 96 Ford F150 dual piston. It comes complete with a bracket which locates the caliper and pads. To adapt to the spindle it will require basically a flat plate which will bolt to the spindle using the old backing plate mounting points, and the calpier will then bolt to this plate. This is the stage where I am right now. Once I complete the adaptor plate I will take some pictures and post in detail all the steps and part #'s used. This will require a 16" or larger wheel and I have no idea on clearance with stock wheels. I doubt the caliper will clear a stock wheel. I'm using new GM 3/4 ton 16x6" five spoke steel wheels, they will clear the stock tie rod ends by about 1/2". For the correct lugnut to adapt this wheel to the rotor go to www.ezAccessory.com. Life is busy right now so it might be a couple of months before I post any finalized info. Be patient I'l post it eventually.
