2 members (Otto Skorzeny, 1 invisible),
92
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 12 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 12 | What is the best way to remove a front fender that has seam sealer in the joint with the cowl. It is painted. Yhanks
Jeff Mather
| | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | What vehicle? ,if it is a ad truck and you are trying to save the paint then maybe a very sharp box cutter to cut the sealer ,then see what it was hiding underneath and have a few pop and come back with a plan. | | | | | Joined: Nov 2020 Posts: 12 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 12 | Thanks. It is an AD. I liked your comment about stopping and drinking a pop or 2. I have learned that lesson😀. I ended up carefully using an oscillating multi tool with a scrapper blade and proceeded carefully from inside wheelwell. Worked well without damage to paint. Thanks again.
Jeff Mather
