1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1389587 12/23/2020 8:41 PM
What is the best way to remove a front fender that has seam sealer in the joint with the cowl. It is painted. Yhanks
Jeff Mather
Mather #1389753 12/25/2020 2:12 AM
What vehicle? ,if it is a ad truck and you are trying to save the paint then maybe a very sharp box cutter to cut the sealer ,then see what it was hiding underneath and have a few pop and come back with a plan.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Mather #1389804 12/25/2020 4:26 PM
Thanks. It is an AD. I liked your comment about stopping and drinking a pop or 2. I have learned that lesson😀. I ended up carefully using an oscillating multi tool with a scrapper blade and proceeded carefully from inside wheelwell. Worked well without damage to paint. Thanks again.
Jeff Mather
