7 members (Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible), 34 guests, and 10 robots.
Topics128,012
Posts1,055,312
Members48,419
#1389190 12/20/2020 9:32 PM
What’s the best way to install the windlace rubber in the channel. What’s the best rubber mfg to use ? 1953 3100
flattop49 #1389214 12/21/2020 12:01 AM
flattop49 #1389284 12/21/2020 5:15 PM
flattop49 #1389438 12/22/2020 3:34 PM
I placed the rear groove of the rubber in the channel and then used a plastic trim tool and pushed in the front edge as I worked my way around. Windex helped. Took about 2 hours for the first one, then I got my technique down and cut an hour off that for the second one.
flattop49 #1389441 12/22/2020 4:15 PM
I put mine in hot soap water to loosen it up, then did the same with a plastic tool. A couple things that helped. If you use a paint can opener you can open the channel up in places it’s tight and use a squirt bottle with soap water to spray on rubber to help lube it up.
Chris
flattop49 #1389453 12/22/2020 6:11 PM
I seem to remember only taking 15-20 minutes per side. Maybe 30 minutes tops. Open up any pinched areas, wire brush the track, lube the rubber with dish soap, slide in one side, slide in the other side, then push and tuck the top area.
flattop49 #1389483 12/22/2020 10:02 PM
Mnsmith,
You are the man if you did it that fast. I spent that much time yelling cuss words!
Chris
flattop49 #1389510 12/23/2020 2:11 AM
Chris...did you use the same words I did?!!!
flattop49 #1389517 12/23/2020 3:15 AM
My kids were at the neighbors and it was probably the most colorful words I have used in 26 years in the military! I’m sure we used the same ones and I might have invented a few.
Chris
Moderated by  ndkid275, Phak1
