7 members (Peggy M, mick53, Steelonsteel, Otto Skorzeny, Robert Crandall, Charles in CA, JW51),
130
Mod | | | Forums66 Topics128,109 Posts1,056,267 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | I'm in the market for an angle grinder primarily for removing rust. It will be my Christmas present to myself.
I'm thinking a compact design with battery power would be good for working in tight places and for the frame. Any advice on brand, battery power, compact design models, etc. ?
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | If you do that, buy lots of batteries and an extra charger. My 4 inch Makita angle grinder plugs into the wall, and the battery never runs down. Jerry
| | | | | Joined: Nov 2004 Posts: 2,409 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,409 | The ones I like have a paddle switch. Way easier to use. I've had good luck with Dewalt, Makita and Bosch rechargeable power tools.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | I have a Milwaukee M18 FUEL 2780-20 Cordless Brushless Grinder 4 1/2 5" 18 Volt. I love it. It runs a long time. Gets in hard to reach spots. I also have the Milwaukee M18 2663-20 Cordless 1/2" High Torque Impact Wrench 18 Volt. Not Cheap but worth the investment! Again, the Batteries last a Long Time. (Same batteries ONE charger!) Good Luck & Merry Christmas. Todd
1950 Chevy 3100
| | | | | Joined: Sep 2010 Posts: 2,315 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,315 | Just remember with a battery it might be a little bigger and heavier and you will have to charge it and may need extra batteries .With a cord grinder good for if you need it in a power outage or out in a scrapyard or field . | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I like my makita corded
When I was cleaning up my frame I got a HF CHEAPO and kept a cup wire wheel on that. Had a flap disc on the makita
Was worth it for time saving
If I get a battery operated one i’lll just get the same brand as my drill , bosch | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | I bought two HF units, the $10 one which has a slide switch that is a PITA to use, and it wore out the shaft bushing when I put a cup brush on it. The other was the $20 paddle switch unit that has been my go-to for my restoration work. It's still running strong since I bought it at least 4 years ago. When the really cheapo one went bad, I bought a spare paddle switch unit for backup. It hasn't seen any service yet, and I'm on the downhill side of needing it for my truck work. All of them are corded. My experience with battery powered drills/impact drivers is that when you need to use it, the battery needs charging, delaying the work.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2012 Posts: 843 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 843 | We use 125 mm Milwaukee fuel grinders to cut rebar and give them a pounding very reliable I would say bulletproof but have used HRL s gun and see what damage they do battery technology is a lot better now
| | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | My best grinder is a Makita 7", I bought it new almost 40 years ago and it has never let me down, zero failures and zero maintenance.
| | | | | Joined: Aug 2007 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 23 | I too have a 40yo 7" Makita. Takes both hands to carry it around but made to take a beating. The type of work you are planning is 1)crappy, so you want it to go as fast as possible and 2)Very hard on the grinder.
I have several air grinders, the big 7", several 4.5" grinders and a cordless Dewalt. The cordless is good for quick (15min) jobs away from a 120v plug. The air grinders are more for medium load, non-stop, hours of continuous running (they are light and generate no heat themselves), the 4.5" are good for heavy metal or paint removal in a small area and the big 7" is likely my first choice for much of what you are describing.
You don't want to skimp here. | | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | Ditto- - - -when something absolutely, positively HAS to get ground down, my big Makita 7" comes out and the job gets done! With the right disc, it even smooths out concrete! Jerry
| | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | Thanks guys for all your advice and Merry Christmas
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | My 30+ year old off brand angle grinder finally gave up on me last week. Maybe Santa will have an extra in his sack.
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | If you are intending to do any real grinding and sanding, a corded version is a must. I like the small 4 1/2 inch diameter models as they are light so they don't wear you out holding them. Any bosch, makita, or dewalt brand is okay. I never liked the switches on the cheapo versions. | | |
