5 members (DadsFirstPickup, 5 Window 9434, TUTS 59, Jon G, 1 invisible), 111 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
1954 3600
I'm trying to get an estimation of how much you all would think a finished bed would weigh? I'm currently about to order a driveshaft and I want to load the rear end up with an approximate amount of weight. I remember taking it off and it was not easy in the least, but it was long enough now I couldn't even guess.
Thanks!
My guess would be 250-300 lb. Maybe a bit more. I'm assuming the bed is still off. Can you get to it to check? You could stick a scale under each end and add together what you get.
Or you could measure it and add up the area of the components. 16 gauge steel weighs 2.5 lb/sq ft.
Can you look at Mar-K for aftermarket replacement panels and check shipping weight? Then guess at rear fenders and that should have you in the ballpark at least.
Unfortunately, Mar-K doesn't show shipping weights on their website, but a call to them might reveal the info needed.
Here's some related info that might get you close. Taskforce bed weight guess
Its off but shoved up in the corner, it was such a hellish process I don't dare touch it and dig it out from under the other body parts. My guess is it'll be 3-400ish as there's a big steel rear bumper and the prior owner had some concrete in the fence post holes.
That's perfect thank you!
big_eek
For what it's worth, concrete weighs ~150 lb/cubic foot.
