8 members (Ridgeback, GMCJammer51, Biermann, Danielbolt, sron48, GIJOE298, Phak1, DadsFirstPickup),
111
Mod | | | Forums66 Topics128,154 Posts1,056,835 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2019 Posts: 57 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 57 | 1954 3600
I'm trying to get an estimation of how much you all would think a finished bed would weigh? I'm currently about to order a driveshaft and I want to load the rear end up with an approximate amount of weight. I remember taking it off and it was not easy in the least, but it was long enough now I couldn't even guess.
Thanks! | | | | | Joined: May 2015 Posts: 11,131 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,131 | My guess would be 250-300 lb. Maybe a bit more. I'm assuming the bed is still off. Can you get to it to check? You could stick a scale under each end and add together what you get. Or you could measure it and add up the area of the components. 16 gauge steel weighs 2.5 lb/sq ft.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | Can you look at Mar-K for aftermarket replacement panels and check shipping weight? Then guess at rear fenders and that should have you in the ballpark at least. | | | | | Joined: May 2015 Posts: 11,131 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,131 | Unfortunately, Mar-K doesn't show shipping weights on their website, but a call to them might reveal the info needed. Here's some related info that might get you close. Taskforce bed weight guess
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2019 Posts: 57 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 57 | My guess would be 250-300 lb. Maybe a bit more. I'm assuming the bed is still off. Can you get to it to check? You could stick a scale under each end and add together what you get. Or you could measure it and add up the area of the components. 16 gauge steel weighs 2.5 lb/sq ft. Its off but shoved up in the corner, it was such a hellish process I don't dare touch it and dig it out from under the other body parts. My guess is it'll be 3-400ish as there's a big steel rear bumper and the prior owner had some concrete in the fence post holes. | | | | | Joined: Jun 2019 Posts: 57 'Bolter | | 'Bolter Joined: Jun 2019 Posts: 57 | Unfortunately, Mar-K doesn't show shipping weights on their website, but a call to them might reveal the info needed. Here's some related info that might get you close. Taskforce bed weight guessThat's perfect thank you! | | | | | Joined: May 2015 Posts: 11,131 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,131 | the prior owner had some concrete in the fence post holes.  For what it's worth, concrete weighs ~150 lb/cubic foot.
