5 members (John Dlugos, 1955 1 Series, Oswald, klhansen, 1 invisible), 281 guests, and 2 robots.
Topics128,101
Posts1,056,179
Members48,436
#1388517 12/15/2020 8:34 PM
I'm installing a '95 LT1 in my 3100. What if any aftermarket radiator should I purchase that accommodates not only hose alignments but also fits original shrouds?
You can buy a 3-4 row aluminum radiator off of eBay specifically for your truck. Direct bolt in with no modifications. Just read the description carefully before ordering. Usually less than $250.
Crusing in the Passing Lane
That is the only option now that Walker is going out of business.
Ed
Crusty Old Sarge
Crusty Old Sarge
Cold Case Radiators make a nice product, a little pricey but great quality. https://www.coldcaseradiators.com/products/fitment/1950-Chevrolet-Truck-any
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
FWIW, I got this summer one of the US Radiator models for my '53 Bel Air, and it is gorgeous (photo below). Stamped tank, copper/brass (although they make identical models a bit cheaper in aluminum). Made in USA. My unit is essentially a stock replacement (but with integral transmission cooler - Powerglide car), and fitment is perfect, unlike some of the off-shore sourced aluminum radiators. I have used the less expensive aluminum ones in the past. No longer.
US Radiator has options for several styles, depending on original engine or swap, with or without integral transmission cooler. They have specific units for Chevy V8 swaps into the trucks.
If sourced from one of US Radiator's authorized dealers, they can beat list price by more than 30%. Just FYI, I used Todd Walton - Walton Fabrication - and recommend him for his customer service.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
my primary radiator for my 292 is tig welded with 2-1 1/4" rows and a 3300 cfm chrome fan on it. It was a little north of $1000. My secondary Davis horizontal mount radiator 16" x 18" (I think) with spal fan was $850. The secondary electric water pump was $350. So as said above how much do you want to spend and what do you need or want. Always over engineer and leave room to grow. JMHO.
