| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | hi for myb 49 i got a 79 c10 rv here was thinking of maybe using the coloumn and steeringbox? also got a 72? lincoln steering box
would any of this work ok
also maybe a whole 1990 rs camaro what parts can i use from the camaro its a 305 manual ok i can use the motor/trans rear end but anything else there worth taking to make fit? | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I am unsure of as to why, but if an aftermarket unit like 'Flaming River' or other is not used then the most common salvage yard unit around here is a GM column out of a van.
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | All depends on your level of expertise, and amount of tools you have. Not to mention ,patience,extra $$$$,welding ability,extra $$$$,workshop availability,and $$$. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Living in the UK might make finding parts a bit difficult. You might have to just try to fit what you have or can find. Let us know how it works out. You might discover some parts that work no one has used yet. Good hunting...
~Jim
