Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Maybellene, Hotrod Lincoln, Otto Skorzeny, Bill Marlow, baldeagle, 1 invisible), 58 guests, and 5 robots.
Topics128,006
Posts1,055,268
Members48,418
#1388067 12/12/2020 10:38 PM
I took my differential apart so I can replace the ring and pinion gear with a higher gear one. Looking at the axles I would like to replace one if not both of them. Can they still be bought new? Thanks
Jeff LaCrone
Depends on what axles you have. Is your truck 1/2,3/4, 1 or 1.5 ton?
Pics of the axle will help.
CC101 1/2 ton.
Jeff LaCrone
Assumption: your axles are not bent. The splines are ok. Bearing surface is pitted or worn.
I have not seen a new manufactured axle from my experience. Finding NOS axles may be possible, but I have not run across any in my search.
You can recondition the original axles by having them machined or turned on a lathe and finding a bushing that is heated and slipped on the turned segment where the bearings ride.
Some have done that here and located a new bearing set to fit the bushing and hub. I can’t recall if it would be an undersized or oversized bearing. A careful search here may yield that discussion or some may chime in.
That approach may be your best bet if your axles need it.
1946 GMC Project
"Back-in-the-day Restore"
The splines are what I don't like the look of. I have a decent set located but they have surface rust the bearings run. If needed they could be repaired like your saying. Would anyone have the bearing number for the ones on the center carrier and the axle bearings?
Jeff LaCrone
