2 members (Gdads51, 68ironhead),
174
0
Mod | | | Forums66 Topics128,110 Posts1,056,251 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Anyone with a good source (price wise and quality) on ABS door panels? and has anyone had the panels covered with the same material as the new seat upholstery? Thanks, and Be Safe, Mike | | | | | Joined: Sep 2010 Posts: 2,313 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,313 | Try whitewolfspeedshop ,I may be getting a headliner from there | | | | | Joined: Mar 2014 Posts: 4,498 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,498 | If you're handy with a jig saw, you can use Formica for both the door panels and the headliner. Formica (if you buy the matte style) can be painted or covered with vinyl. That is a hint not to consider the glossy type. It is much thinner than the ABS panels, and tougher. Use heat to bend it (for the sharper bends of the headliner). No matter what on earth happens, it will not shrink nor buckle from temp changes or humidity. Think of it as very thin cast iron.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | Jon,
I used uncovered Formica and love it! Easy to clean also!
Chris | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Whitewolf is what I/m looking for, thanks all for replies. Mike
