2 members (ShopRag, GradyB), 116 guests, and 1 robot.
Topics128,035
Posts1,055,564
Need to find the correct part to connect my manual throttle cable to the throttle linkage on a Rochester b carb. some sort of stop nut to attach??
Also where is the register mark that the pointer on the distributor clamp gauge points to? A picture showing both would be much appreciated.
1953 3100 Pu
You have the wrong bracket on the carb for a manual throttle equipped carb. The correct one has two loops to attach cable housings- - - -one pointed toward the choke bell crank and another that points straight down toward the throttle bell crank. The manual throttle cable fits through the hole in the linkage instead of a cotter pin, and a round brass piece with a setscrew allows the cable to pull up on the linkage. Normally, the linkage rod slides up and down on the cable when the throttle knob is not pulled out.
Scrape the paint off the block- - -there should be a mark stamped there that lines up with the octane selector. Center the octane selector on that line, lock it down, and use the pinch clamp around the distributor housing to adjust the timing.
You have to sometimes look very carefully for the mark. This is on a 62 motor that I purchased from a fellow two years ago. Complained that it never had the power he thought it should have. If you look carefully, ignition timing was retarded, amongst other problems.
Mike
Swami, I have a couple pictures of that bracket for your carb, PM me if interested.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Heres a cable stop nut
https://www.oreillyauto.com/detail/...018/chevrolet/traverse?q=03337&pos=0
OK- - - -I should have enlarged the picture a little- - - - -you've got the right bracket. All you need is the brass sleeve with the anchor screw. Push the throttle cable through the hole in the gas pedal linkage, and attach the stop to the cable far enough below it that it won't interfere with setting the idle speed. Then when you want to increase the engine speed for some reason, just pull the throttle cable knob. Hopefully, the cable sheath will have enough friction to keep the speed steady- - - - -some aftermarket cables don't.
AD Addict & Tinkerer
“Hopefully, the cable sheath will have enough friction to keep the speed steady- - - - -some aftermarket cables don't.
Jerry ”
Mine, I bought from Classic Parts, did not. I even tried putting three kinks in the internal cable but still no good. The accelerator spring is just too strong. I basically bought it to fill a hole in the dash bit I did hope it would work!
[EDIT] A trick for cutting the cable to length is to run the cable to the clamp with a bit of slack, then pullout the throttle about 4 inches and cut thru both the outer sheath and the inner cable. Push the throttle back in, then continue with hooking it up. I used a cutoff wheel on my side grinder to cut the cable.
Phil
Project Journals
Stovebolt Gallery Forum
Heres what it looks like on my carter
My bracket is a little different than yours .
Phil, there is a way to make a tensioner for the repop cable that will keep it in whatever position you choose. It's a fairly simple sleeve that slips over the cable sheath, with a couple of Allen head setscrews. Tighten the setscrews to crush the cable housing a little and create some friction on the inside wire. It's a very simple machining project to make one.
Thanks all !That clears it up for me. As far as throttle cable tension goes this one seems plenty stiff..... pretty sure it `s the original .
1953 3100 Pu
I had the same problem with my throttle cable as well. I had it hooked up correctly, but the throttle spring was too strong and therefore forced the dash knob to stay against the dash. I haven't messed with it any further, however I did drive a friends '54 with a 235 recently, and the throttle cable worked perfectly. Really came in handy on cold starts for warming up the engine.
-Patrick
1953 Chevrolet 3100
I think I’ll be on the lookout for an original cable to replace this overseas crap. In the interim, it fills the hole!
Phil
Project Journals
Could someone please post a picture or pictures of both the choke and throttle cables from where they leave the firewall all the way to the carburetor attach points. On my 1947 Chevy 3100 at some point someone put on new choke and throttle cables...but rather than cut them to size they just wrapped them around the base of the carburetor. They work but it looks real tacky under the hood. Thanks, ray
Former BMW Rider
Former BMW Rider
Hey Ray,
I also responded to your questions via email. Let me know if you have any other questions.
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
For replacing the cable housing, go to your local bicycle shop and ask for bicycle brake cable housing.......OMG!
Craig
Question. How does everyone lubricate inside the sheathing to keep the cable moving easy?
Thanks for any replies
Former BMW Rider
Former BMW Rider
My cable is new; however, I removed the inner cable and gave it a liberal coating of light oil prior to installation. Some will simply oil the exterior cable housing and let the lubricant 'bleed' its way to the inner cable. The more adventurous will remove the inner cable and slather it with oil, oil the cable housing, and then spend the rest of the afternoon trying insert the inner cable into the housing......... grin
Andy
2 Offline
I found that Oil attracts the finest of dust and makes a mess
I use wax instead and so far seems to be good enough
Besides the friction helps it stay put smile
You got to pull out the wire for wax, but I do that before installing it
Haven’t lubricated them since installed
-s
Thanks for that suggestion, 2ManyTrucks.
Pull the inner cable and grease it. Stick it back into the outer cable housing.
Craig
