| | | Forums66 Topics128,014 Posts1,055,329 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | hey gang, really confusing rite now took rear apart axle splines are 17 , on the chunk its stamped M A 518 . m a is a truck chunk, splines should be 26/28? any help would be great. also on the pinion gear itself is stamped 3789391-10-39. number on chunk is 3707340 is it car rear truck it is 10 bolt. but wicth one????
1961 apache
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | It would be helpful to indicate what year, make, and model vehicle you are working on. However, the 10-39 would indicate a 3.90:1 ratio. The most common rear end used on TF trucks such as my 56 have a 10 bolt housing with a 3.90:1 ratio. I'm not sure offhand what number of splines are on the axles. Fred
| | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | thank you rfs56trk for responding. i do have pics of the rea in the project journal under my name.1961 apache 6 banger with 3 on the tree. their are 4 diffent 10 bolt rears i just want to know is it 7.5/7.6/ 8.2/8.6 ? i would like to get a posi for it. now im finding 17 spline is car axle?
1961 apache
| | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | I put the year, type and other relevant info for my truck into my signature, where you have “id rather be playing”. This way every post you make has the info we all need to better answer your/our questions.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | What you have is what is known as an Eaton "corporate" rear end with the drop out center section. I believe it was referred to as a H033. It was common to 1/2 ton trucks from 55 through 62. There isn't much available except an aftermarket 3.36:1 gear set. I don't believe there was a posi available for that unit, but if there was it would have been extremely rare. There are many 10 bolt rear ends in both cars and trucks in later models but it's unlikely that any of the internal components interchange. Fred
Note: The spare axle(s) I have for my 56 have 17 splines.
| | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | What you have is what is known as an Eaton "corporate" rear end with the drop out center section. I believe it was referred to as a H033. It was common to 1/2 ton trucks from 55 through 62. I don't believe there was a posi available for that unit, but if there was it would have been extremely rare. Fred Clutch type limited slip carrier was an option, at least in later years. Had on 30 + years ago, couldn't find clutches, etc.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | thank you all for the info, really helped
1961 apache
