1 members (CuzzFuzz), 83 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
Apprentice
Apprentice
All,
I have a 55 second series frame that was previously fitted with an early camaro subframe.
I want to increase the ride height in the front end so the truck sits up a bit more.
What would be the best way? Are there taller springs available? should I just use spring spacers?
Any ideas?
Carl
CCB
There are no taller springs, but maybe big block springs will work. I put (2) 1 inch spacers in each side to raise mine up a bit. Is it possible those springs have been cut? Stock, uncut springs measure 16in uncompressed. So if you remove them, cut springs will just fall out and uncut will have to be pryed out.
Hope this helps.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
I used QA1 adjustable coilovers.
Apprentice
Apprentice
Thanks guys,
I will have to pull the springs out and check them for height.
I'm affraid that on my budget I cannot afford to buy the coil overs right now.
Wilbur: What kind of spacers did you use? Are they picture on your website?
Thanks again!
Carl
CCB
I just used the twist in type found at many parts stores.
