7 members (Hotrod Lincoln, Dave1234, IHPWR, TUTS 59, Peggy M, Wayne67vert, 1 invisible),
72
Mod | | | Forums66 Topics128,206 Posts1,057,440 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 6 New Guy | | New Guy Joined: Nov 2020 Posts: 6 | the drive line on this old truck seems to be leaking the gear oil just where the line connects to the trans. now am i going to have to find a new line for this truck or is there a gasket or bearing that can be replaced to remedy the problem. also additional inf0 on this gmc is that it has the 228 motor in it and so far me looking up parts for it has been somewhat of a pain seems to me that this motor and the parts for it were not very sought after making it hard to find them i cant find a new water pump for it anywhere. the current one it has is still functioning but looks like it would go at any moment. any ideas what i could do.
will send pictures on the driveline soon. | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | 228 parts are alittle harder to find.........but.........the GMC a engine is far superior to the 235 in insert bearing and full pressure lubrication. The are several other recent posts on all the differences.
Ebay has pumps and rebuild kits........they are pricey. I bought a pump couple of years back for 1/2 the current price. | | | | | Joined: Nov 2020 Posts: 6 New Guy | | New Guy Joined: Nov 2020 Posts: 6 | Yeah I was looking on Ebay they were in the range of 250 to 400 but most either didnt have the pulley size i needed or didnt have one at all. And I dont know if I can take my pulley off. | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Several of the ebay sellers will supply a different pulley on request.
I upgraded to alternator and swapped the alternator pulley to match the crank and water pump.
If you have press and skills ( or friend or skilled machine shop) ........the new bearing and shaft for $150 is another route.
| | | | | Joined: Jan 2019 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 21 | I just had my water pump rebuilt by EGGE. (California) They sell a lot of parts to rebuild your GMC 228. $160 plus shipping to rebuild it.
1949 GMC 100 1/2 ton 1969 Stingray convertible 2011 RS/SS Pace car
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Jbear,
250, etc., engines are different, modern series(194, 230, 350, 292) series started in 1962, so be careful in your search for parts.
228 through 302 series fit your truck, 302 parts easier to find than 302.
Ed
| | | | | Joined: Nov 2020 Posts: 6 New Guy | | New Guy Joined: Nov 2020 Posts: 6 | So everything through the 302 series are going to be mostly interchangeable with my 228 | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Yes, for the most part ( pun not intended)- what will not interchange is the crankshaft, flywheel and connecting rods.
All bolt on external parts, camshaft, heads, rockers, pumps, bellhousin g, starter, oil pans, covers, will fit and interchange.
As you get deeper into your project we can help you sort out some things as you ask more specific questions about your build.
If you have the option to step up from the 228, consider a 270 or 302...if you are not concerned about keeping the block original to the truck.
1/2 or 3/4 ton truck (open driveline? or torque tube)?
Do you have the repair manual?
| | | | | Joined: Nov 2020 Posts: 6 New Guy | | New Guy Joined: Nov 2020 Posts: 6 | i dont have a repair manual. and it is the sealed driveline. i am trying to keep it all original so i am going to keep the 228 but who knows the future ,aybe i will change it out. i have a friend with the 270 and it is pretty mean. | | | | | Joined: Feb 2019 Posts: 4,516 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,516 | First, welcome to the “Bolt”! Your first purchase should be the 47-55 GMC Maintenance Manual. You can also find them on eBay. You will find it an invaluable source of information you will need the restore your truck. Plenty of help here though and all you have to do is ask!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Dec 2013 Posts: 795 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 795 | i dont have a repair manual. jbear-PM sent. Click on the red flashing icon in the upper righthand corner, thanks!I went through all of these issues with a 228, so I've felt your pain. I had to send in my water pump and have it rebuilt. That being said, it was a strong running motor, but it was in my Chevrolet and the installation was a mess. I've got a line on some GMC parts here in Iowa. So if there's something specific you need, let me know. It's an incomplete truck, but you never know. Good luck,
Last edited by HandyAndy; 12/07/2020 10:28 PM. Reason: Additional information added.
| | | | | Joined: Nov 2020 Posts: 6 New Guy | | New Guy Joined: Nov 2020 Posts: 6 | thank you i will keep in touch | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Your 228 might have a small flywheel, which is too small for a 302, so it might be a good time to see what flywheel you have. Chevy flywheels can be drilled in alternate locations with GMC bolt pattern. Make sure to check ring gear teeth, especially if you might be thinking about 12 volts.
Ed
