7 members (Rusty Heaps, Bill Hanlon, Gdads51, Joe Franken, Charles in CA, Perro, TUTS 59),
68
Mod | | | Forums66 Topics128,179 Posts1,057,134 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | Hi guys, is there an dually axle beside the dana60 or 70 that is the same size (width) and 10bolt hub that will work with my truck? Reason I am asking is I want to try to go 3:23 or so on the rear ratio. Thanks.
'38 1.5ton; "The stuff is as tough as woodpecker lips"
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | "Good Grief, Charley Brown!"
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Modern rear Dana 70 and 80 will bolt right in, be faced with disc brakes on many, 5.250” hub diameter, modern 19.5” wheels approximate original diameter, many modern ratios available.
Matching front disc. Brake axles avail.
Ed
| | | | | Joined: Oct 2019 Posts: 238 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 238 | While you may find a rear that will swap in easily that is 10 lug, The front axle swap will be the difficult part. If you don’t swap both, you’ll have to run different rims front vs rear. And the front axle will be too wide for your 38, you’ll have to find someone to narrow it unless you want the tires sticking out past the fenders.
The only 10 lug axles such as those I know would be the f450 and Chevy 3500HD from The mid 90s. But again, if you swap only the rear, you’ll Have different bolt patterns. If there is an easy solution, many of us haven’t found it yet.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Tony,
The GMC 3500 HD front axle I got for my ‘55 is about 80” from wms to wms, so I will have to use the spindles only. I used a front axle from. P-3500 HD on my ‘37 T-18HD, although since the fenders and running boards are not connected to the cab, I spaced those out 1.5” and they fit fine.
Ed
