0 members (),
125
10
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | Is it possible to connect a 4L60E transmission to the original speedometer on a '50 3100? If so, what provisions are required? | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | A very possible way is Abbott Tachograph here. Never used them but they're a small company that's been around for 50 years. The owner started out designing/building/supplying data loggers/tachographs for the trucking industry. Good Luck, RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | Jegs sell their version of the “cable X” too. Its just a VSS electronic input (from trans) then it has a board that does the calculation and drives a electric motor that drives a stock GM speedo cable. I have seen them previously used in older swap muscle cars and I will be installing one in a turbo LS 50 chevy pickup very soon. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We don't use cable or electronic speedometers anymore but rather GPS units that are not affected by gearing or tire size. Only around $60 but no one has come out with a 5" face one for a direct fit into an AD truck. Someone has dropped the ball on this since there would surely be a market for such. The <> 3.5" face ones with a custom made bezel are okay but not right.
Evan
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | You can swap the tailshaft housing for one from an older TH700R4, with a mechanical speedo drive. Then you may need a custom-made cable with the correct ends, I do not remember what kind of cable I had used on mine. Changing the tailshaft housing also makes it easy to change the driven/drive gear, so that the speedo is correct. No electronics, OEM simplicity and reliability.
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | If your tailshaft is the later 8 bolt version, you're out of luck. The cable x style system is it. | | |
