| | | Forums66 Topics128,211 Posts1,057,472 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 44 Member | | Member Joined: Jul 2006 Posts: 44 | I have a 1951 chevy truck 16inch rim that I would like to put a large bias ply tire on. It is for the rear of my rat rod. I would like to use a 700 or 800 size tire??? Kind of that big tire in back, small tire in front look. | | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | you could get the rim widened as well..then you could go as wide as you want... I know a 700 fits the stock rim..
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | | | | Joined: Jul 2006 Posts: 44 Member | | Member Joined: Jul 2006 Posts: 44 | Where can I take a rim to be made wider? How much does that run? Could I put on an 850 then? | | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | do some research in your area, there will be a shop that does it.. or try these guys.. http://www.stocktonwheel.com/wheel_widening.htm I have heard that they are good but they take a while
