4 members (EchoBravoSierra, carbking, 2 invisible), 77 guests, and 2 robots.
Topics128,206
Posts1,057,438
Members48,471
I have a 1951 chevy truck 16inch rim that I would like to put a large bias ply tire on. It is for the rear of my rat rod. I would like to use a 700 or 800 size tire??? Kind of that big tire in back, small tire in front look.
you could get the rim widened as well..then you could go as wide as you want...
I know a 700 fits the stock rim..
"I'd rather have a bottle in front of me than a frontal lobotomy."
-D. Parker
1951 Chevy 3100
Where can I take a rim to be made wider? How much does that run? Could I put on an 850 then?
do some research in your area, there will be a shop that does it..
or try these guys..
http://www.stocktonwheel.com/wheel_widening.htm
I have heard that they are good but they take a while
-D. Parker
1951 Chevy 3100
