Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (60steve, J Lucas, NJC, klhansen, TooMany2count, Lightholder's Dad), 150 guests, and 0 robots.
Topics128,277
Posts1,058,451
Members48,490
My 1949 GMC FF 350 COE eats up flywheel ring gears. Engine is a 1955 248 GMC repower.
By the looks of Jim Carters catalogue a new ring gear is 40$ No problem. (I converted from 6 volt to 12 with an alternator. Starters rebuilt with new drive.)
What I need help is which ring gear count to get as Carter offers 139,153 and 168. All seem to use the same starter drive. Presently the truck has a 139 count (maybe original?,been flipped.
Am I using the wrong tooth count causing the failure? (less teeth means more room for the bendix pinion gear to engage? Aye yi yi.
Can someone give me direction?
Thank You
The extent of my knowledge is..... The starter drives are NOT the same. The experts will be along shortly to guide you towards success. Good luck.
6 volt starter running on 12volts with 139 tooth ring gear is the correct combo.
12 volt starter would use the 159 ring gear.
There several prior posts on starter identification........the starter drive (shafts) are different diameters. Red and black labels.
Thank You for helping me sort this out. 70 years of previous owners repairs have kept me guessing.
