3 members (Shaffer's1950, Bill Hanlon, Gdads51), 96 guests, and 3 robots.
Topics128,150
Posts1,056,985
Members48,460
#1385324 11/20/2020 11:08 PM
I am in the process of finally starting this rebuild project after 6 years on hold. I am knocking out the U joints and need to pull the center bearing but am having issues with how it separates from the drive shaft. I am guessing the metal retainer on the shaft at the base of the splines has to come off??? Or does the whole carrier assembly slide off the end of the shaft??
Any help would be appreciated so I don't inadvertantly damage something.
Cheers
1954 GMC 1400-9430
7
7 Offline
The bearing is pressed on to the shaft, the silver cup is just a slinger, won't do much good to remove it, you'll still have to press the bearing off.
Here's a couple of illustrations that may help. I replaced the entire carrier bearing assembly on my 1954 3604. If you have a Shop Manual, it helps.
Ron - - Dusty53
1954 Chevy 3604
The technically correct way to change the center bearing would be with a bearing splitter and a press, but I've changed a bunch of them on the side of the road with a big hammer and a heavy punch to drive the old one off, and a piece of pipe the right size to slip over the spline and drive the new bearing on with the same BFH. Quite often, a failed bearing has northing but the inner race left on the driveshaft.
All,
Sorry for the late reply. Thanks all who helped with the process. I just did not imagine that the rubber cushion would have had such a hold in the carrier bracket. Just needed more push!
1954 GMC 1400-9430
Most replacement carrier bearings come with their own bracket, so you probably won't need to reuse the old one. If the vertical spacing isn't correct, you might need to add an appropriate spacer between the carrier bearing and the crossmember. The angle between the front and rear driveshaft is important.
Moderated by  Dusty53
