| | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | Will a 53 bed fit on my 54 3100 frame? Just can’t seem to find the answer. HELP. Please | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Nope- - - -the 54 and early 55 frames have a flattened area under the bed instead of the high arch over the rear axle that the 53 and earlier trucks have, so the shape of the bed and the mounting brackets are different. Jerry
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Will it fit---No. Can you do it---yes, IF you have the tools and skill. Have done several (all 55 1st series) for ones that like the shallow bed with angled top rails. Usually done in conjunction with the 47-53 front sheet metal which gives an earlier look with a one piece curved windshield cab. If you have access to a drive on lift with an overhead chain hoist then it is not a difficult swap. Just suspend the bed in the correct position, where running board to bed bottom filler panel fits, and make custom blocks between the bed cross members and frame rails. This has to be done EVERY TIME on an S10 or other chassis swap. Fortunately the swap kit suppliers have dumbed it down to where they are just drill and bolt installs.
Evan
| | | | | Joined: May 2005 Posts: 281 'Bolter | | 'Bolter Joined: May 2005 Posts: 281 | This is an often asked question. I have always thought the early bed will fit on the 54 frame with only re-drilling the front bed to frame holes and using the regular 53 wood mounting blocks. Although we built these beds for many years, we never actually installed this swap to the 54 frame. Measurements would indicate the swap is an easy one. What am I missing?
Mark | | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | Got the lift got the hoist and time. We’re gonna see about the skill. I like the earlier beds just a preference. The truck will have 53 front clip and bed , just cab and frame are 54. Thanks for all the help . Pictures will come. | | | | | Joined: Jun 2020 Posts: 73 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 73 | The truck I picked up this summer is a 54’. But the box is a 53’ style. I’m about to start working on this truck soon. I’ve wondered ever since I got it if this was original or not. From the paint color under the topcoat color it’s the same between the cab and bed. So if it was changed it was done a long time ago. In looking at the door tag my 54’ does appear to be an early 54’. I know Chevy would use carryover over parts on other models and wondered if my truck had received a 53’ bed from the beginning. I’m sure once I get in to the truck more maybe I’ll be able to tell better.
Adam
Adam
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Tim has shown the reason I suggested custom mount blocks---to keep the bed to cab position of the bed the same. Picture is of an S10 frame swap with the tape line that puts the bed in the correct position in relation to the back window. Ones mounted lower look funny to me. Cypress mount blocks last forever. [img]https://i.postimg.cc/G87cRmBw/S10-032.jpg[/img]
Evan
| | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | I’m working with the techs at Mar K to put an early bed on a 54-55 AD frame they already have a kit to put a 54-55 on an early frame. They said that they have never had a request for early bed on a 54-55 frame. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I have met with the owner and I assure you they will help you all they can.
| | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | They did and it’s Great. Only Co to use for all your bed needs. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | 54 with older bed and front clip. You can tell by the large radius of windshield corner that it's one piece. Couldn't find a full frontal picture. We have done a lot of these conversions through the years. The chrome plated running board to bed filler panel is NOT my idea. [img]https://i.postimg.cc/S2L6zW2C/truck-roll-pans-clips-003.jpg[/img]
Evan
