0 members (), 139 guests, and 1 robot.
Topics128,127
Posts1,056,680
Members48,452
Moderated
Moderated
rear core plug is bad, had mass amounts of coolant leaking, looking for the best way to replace the plug without pulling the engine, its a 71 chevy 250 with a powerglide trans, actually in a el camino
Is there room for a rubber expansion plug? They're simple to install if you have enough depth behind the plug for the rubber and the washer to fit properly. Then just tighten the nut until the plug seals the opening.
Do yourself a favor. Pull the engine and replace them all. If one has rusted through the others are not far behind. Shouldn't have to do it again for another 39 years!
Crusing in the Passing Lane
One of the hazards of tropical climate not requiring antifreeze.
Ed
If this is the rear most plug just inside the bell housing area I don't see any other way to get to it than either pull the engine or transmission and flywheel to replace it.
And as already suggested, replace them all at once.
Use brass plugs, not steel. They last a lot longer.
Jerry is right but at my age steel will outlast me. I hope!
