| | | Forums66 Topics128,129 Posts1,056,700 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 2 Moderated | | Moderated Joined: Nov 2020 Posts: 2 | rear core plug is bad, had mass amounts of coolant leaking, looking for the best way to replace the plug without pulling the engine, its a 71 chevy 250 with a powerglide trans, actually in a el camino | | | | | Joined: Feb 2004 Posts: 29,838 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,838 | Is there room for a rubber expansion plug? They're simple to install if you have enough depth behind the plug for the rubber and the washer to fit properly. Then just tighten the nut until the plug seals the opening. Jerry
| | | | | Joined: Jan 2006 Posts: 29 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 29 | Do yourself a favor. Pull the engine and replace them all. If one has rusted through the others are not far behind. Shouldn't have to do it again for another 39 years! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | One of the hazards of tropical climate not requiring antifreeze.
Ed
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | If this is the rear most plug just inside the bell housing area I don't see any other way to get to it than either pull the engine or transmission and flywheel to replace it.
And as already suggested, replace them all at once. | | | | | Joined: Feb 2004 Posts: 29,838 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,838 | Use brass plugs, not steel. They last a lot longer. Jerry
| | | | | Joined: Jan 2006 Posts: 29 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 29 | Use brass plugs, not steel. They last a lot longer. Jerry Jerry is right but at my age steel will outlast me. I hope! | | |
